No turn signals hazzards or brake lights please help!
green00
I have a 2001 Pontiac sunfire All of a sudden I lost turn signals hazzards and brake lights! The things I have done so far..... Changed turn signal hazzard switch on column, changed all relays flasher and non flasher, changed brake light switch, checked all fuses none blown, light bulbs have been checked... I have power to the fuse panel under hood to all circuits however I do NOT have power to my brake/hazzard fuse inside driver door I also have no power at the brake light switch! Ive looked over all wires as best as I can see cant seem to find any wires broke! I was told there mite be a fusible link along driver fender and havnt found it yet! The car also has a after market alarm system dont know if that helps any? Any suggestions would be greatly appreciated!
I'd start by removing the alarm system. Most aftermarket alarms are either tied into the turn signal, or park lamps.
alarm system
Thank you for responding! I have unhooked all plugs going to alarm system and still nothing! Any other ideas?? Thanks again in advance......
i have 01 sunfire with no turn signals or brake lights. 3rd brake light doesnt work either. i already changed the multi function switch, brake switch...fuses good. changed flasher...
help me please. cant drive it
