oil consumption
jt9940
torrent consuming oil with only 43,500 mi. I have inspected for leaks and can't find anything. oil is changed every 3,000mi. anyone got any reasoning or a solution to this it just started at about 38,000 mi. I have always used castrol gtx 5w-30. I used a fully synthetic 5w-30 pennzoil oil on my last oil change based on a mechanic friend who suggested it ,but it made no difference still consuming same amount of oil.
did you check if you engine uses a PCV. How much oil does it use in 3000?
i have not found a pcv valve and i am using a little more than a quart of oil per 3000mi. i believe no pcv for this engine.
well you dont mention what year and if you are the original owner, does it still fall within the 5 year 100k factory warranty? You can also try switching to 10W30.
Its a 2008 and I am the original owner. According to a local dealer a quart burning every 2000 mi seems to be exceptable according to gm, is what I was told! I have owned a few cars new and used all GM and never had an oil consumption issue.
