I have an 02 grand am...I kno when you do the oil change you have to reset it so the oil light will go off...I know where the reset is...Cars have tricks...Whats the tick...Ty
if you havent figured it out yet try turning your key on and off 3 times without starting it then while the key is in the on position the third time hit the gas pedal 2 or 3 times you should here a beep that youve never heard before. alot of gm products are like that if you dont have the actuall button. thats what i had to do with mine and its only a year newer than yours.
