Malcontent
MY sunfire has been messed up since I used bars leak radiator stop leak.
It stopped the leak and it started overheating. Heat started working and not working, now it hasn't worked last few days except maybe 10-20 seconds a few times while driving. I thought maybe it clogged the thermostat but changed it and didn't see any residue or gunk in there, water in plastic jug is pretty clear at this point. Someone said maybe air in the system, I opened bleeder valve and also tried removing top hose that goes into plastic jug. If I pull over when it overheats and open jug, it's full and if I take the top hose off the jug and crank it steam shoots out of the hose but no water.
Starting to wonder if water pump is really pumping water.
