I know P0440 says unable to pressure up
P0442 says slow leak in the EVAC system
I would think these codes could cause rough idle and cause the engine to die, but the car ran great up until today. Had power loss, could only run about 10mph, put it in park for 5 minutes then it was okay again for about 20 minutes, then again almost home 10mph then it dies in the driveway. It will barely start and then die.
I physically checked hoses, unable to do a smoke test.
Changed the gas cap.
Reseated some cable connections.
I would think a slow leak or cracked hose would not cause the current condition but could cause the code. I am thinking one of the parts was flaky and has now failed suddenly.
Any thoughts on a high suspect part that could fail and cause this? Would like to try something before spending alot at a dealer.
