ericv1984
I've had my CEL on for a while now and knew it was due to needing to replace my upstream O2 sensor. I decided to get my car scanned again so I went to Autozone and had them test my battery also, since my car was acting like it wanted to die at idle and when it would do this my dash lights would dim. So I got it tested and it said the battery was bad and also I got my car scanned. P0507 came up a long with two other codes. I've already looked up the causes of P0507 and the possible solutions. I plan on working on the car in the morning to see if I can fix it.
When the car sputters/acting like it wants to die at idle, I usually rev the car up to about 1k RPMs so it won't sputter cause I'm afraid of it dying. When the car is in drive, it runs fine, it only sputters at idle. So I was wondering, which one of these would be the more likely cause....
Throttle body
EGR valve
Idle air control valve
EVAP purge valve
EVAP canister
Even though I cleaned the throttle body, cleaned the EGR valve and replaced the EGR valve gasket, and replaced the idle air control valve about 3 months ago. I also replaced the EVAP purge solenoid about a month ago and was going to replace the EVAP purge valve at the same time but I couldn't figure out how to remove it.
The other CELs that are on right now are...
P0420 - Catalyst system efficiency below threshold (bank 1)
P0171 - System too lean (bank 1)
Also, could the P0507 also be due to the oxygen sensor (P0171) needing to be replaced?
Throttle body
EGR valve
EVAP purge valve
EVAP canister
