Hello all,
The passenger window will not raise or lower, I have check the main fuse inside the cabin. Removed the door panel and check that the motor does operate with an external power source so there is not binding of the window or motor.
when check for power to window could not verify since the wire color on the motor is different from what is on the switch.
any suggestions???
Thanks
any suggestions???
Thanks
