zaleonardz
Hi All,
First post here (2nd after the intro) and I would like to start straight off the bat with a technical question.
I have a pontiac trans am 400 with T-tops and she has been standing for a year, and this has got to stop.
I got her in bad shape and have been slowly fixing up bits, with the last being a full service. While the car was idling nicely and I was replacing the shaker scoop, I had turned to go and fetch something, and I heard a "clang"
Top and bottom are not turning together, this can only mean timing chain is gone, and since it was at idle, I doubt there is any damage.
Can anybody detail the procedure for replacing the timing chain on a original 400, I have the Fisher body/mechanical guides but they do not discuss the procedure.
I have stripped off the nose and the radiator, so I have plenty of access.
Is it a simple case of stripping off the water pump and just replacing the chain ?
