Stacey Ruiz
- Jul 5, 2010
Car started not wanting to start & replaced battery. kept on with not wanting to start so had starter replace twice now & had bench tested to make sure I have a good one. Took to a mechanic sd no signal from ignition to ecm & that ecm bad, he put wire in relay for crank and touched to metal to get car to start & drove home and ordered new ecm, installed already programmed & did the security reset, still will not start. Does anyone have any suggestions? Car will not crank, no noise other than fuses clicking when key is turned. Have pulled center console do not see bad wires, under car by drivers door these connectors are fine. I am in CA, car has not been wet.
