PONTIAC FENDER ORNAMENTs
cruiserdog
Does anyone know how to remove the front of the ornament from the fender? I have removed the other two nuts from the studs, but can't seem to see where the front stud comes through in the fender well.
Please help!!!:(
Cruiserdog
what year is the car and what does the ornament look like? If i can find the part with a picture it should be possible to determine how it is attached to the fender.
Removal of the 1962 Pontiac Front Fender ornament or spear.
This is the top of the front fender ornaments or spears on a 1962 Pontiac Catalina through Grand Prix.
For a car of that vintage I recommend you try posting your question at www.oldride.com, good luck with your project.
Great you found an image of it and it's just another stud held on with a nut. Is your problem you cant see it, have you tried a mechanics mirror, extendable rod with a mirror on the end? Is the problem you cant reach it? If so have you tried a 1/4" drive ratchet with a long extension?
