P
petrolino2008
I have a 1987 Pontiac Fiero , my mechanic installed a used engine from a different car, it ended up having a bad engine bearing. My mechanic installed a new set of bearings thru the oil pan, but it once again one bearing spun. Is there a way around fixing the bearing without having the engine rebuilt ? Another question is, It was a used engine that was put in from a different Fiero that was running perfectly fine before it was installed in my car. (previous owner of the engine had an upgrade installed) why would the transplant cause a spun bearing? Thanks in advance!
