Pontiac Grand Am 1998 Trouble?
  • Thread starter Thread starter lady_armand2
L
lady_armand2
It cuts off when it's hot outside. It'll run fine if it's not too hot but on those hot days it'll run for a while but it cuts off eventually. Can anyone help me?
Could be clogged injectors. I don't have a car with injectors, but my sister swears by injector cleaner that you pour into your gas tank. It won't hurt to try it.
When the temperature gets hot outside, there's fewer air molecules per square inch of air. That means the air entering your engine is less dense. If you don't have enough fuel entering into the engine, the decrease in air density in the combustion chamber makes it even more difficult for the decreased amount of fuel to ignite.
Get a tune up to eliminate potential ignition issues, put some injector cleaner in your tank and see if your problem goes away.
If not, you'll may need to spend the bucks to get it diagnosed.
