there isnt one. there is a fill hole ontop but what you need to do is to. start the vehicle and there is a little bolt kind of by the rf extension housing part of the trans. pull that out while the vehicle is running and if fluid runs out it is over full. if nothing comes out, fill untill fluid comes out. let fluid run out untill it stops. install bolt and youre done.
