Pontiac Montana 2004 problems
Jobert279
hello everyone i want some help for a problems on my pontiac montana 2004. The warming systeme didn't work but the AC is working. So i'm just asking if someone got this problems now or got it in the past !
thanks you
p.s : sorry for my english i from quebec so i speak french !
Is your enging running cold? Is your engine coolant low?
est votre moteur en marche à froid? est votre bas du liquide de refroidissement?
i got cold air ! My AC is working but not my warming systeme and it's isnt help my because i got also my gaz and temperature gauge that don't working !
I understood your problem the first time. Is you engine coolant low? Without a functioning temperature gauge we can not determine if your thermostat is stuck open.
I had a stuck open thermostat on my 2000 Montana and if I would let it idle long enough or drive in the city/stop and go traffic it would eventually warm up and all of this was easily see able with the temp gauge.
