L
Lilly
I have a 2002 Pontiac Montana Van. The "side" hatchback brake lights aren't working. The brake light at the top however Is working. I've changed the bulb with 1 I know is good. It still doesn't work. There isn't any corrosion in the socket. The fuse looks good, but I'm wondering if I should switch it out just to make sure.
On this van, the Back up lights, turn signal, brake and regular lights are all separate bulbs. Since the Top brake light works I'm told it's not the Brake Light Switch under the brake pedal.
I don't have much money and I'm trying to diagnose and fix this myself.
If anyone out there can suggest anything, please help.
Thanks.
Thanks.
