Pontiac Sunfire 1995 Turn Signal Switch - How to change it?
Amr
Hi there,
I have a Pontiac Sunfire 1995, no cruise control and I would like to know how to change the Turn Signal Switch.
I do thank you in advance for your time.
Thanks,
Amr
Thanks a lot, it was very helpful.
T/S switch
You have to have a #25 star drive. There are three star screws that hold the surround on just behind the steering wheel. They are on the bottom of the surround. Then once that is off you can see two star screws on the switch unit it self. One on top and one on the side. You can use a 7mm wrench to get to the side one or turn the steering wheel so the top of the air bag area is at the side screw then you can use the star drive to get to the screw. The electrical connections are a tab lock type so just push in on the tab while pulling out the connector.
