pontiac sunfire auto transmission stuck in reverse and gear shift moves freely?
jct4761
put car in reverse backed up...moved gear shifter to drive...car still went in reverse...is there a linkage loose maybe? or, is this a bigger problem?
I had the same issue once. The connection at the transmission where the gear shift lever cable connects is worn out (plastic parts). When the plastic part wears out, it allows the gear selector cable to come out off the lever on the transmission. this requires a new plastic "bushing" to be installed. You can visually check it, it is located on the transmission near the firewall, you will see a lever about 2-3 inches in length where the cable connects to.
