Possibly EGR valve?
Fernando09
Illinois
About 3 months ago I got an engine code for the EGR valve ( P0404) to be replaced and at the same time my stabilitrak and traction control on the car turned off. I have replaced the EGR valve and the traction control and stabilitrak have turned on again but I have gotten the code 2 more times and have replaced the EGR valve since it’s still under warranty but I am stumped as to what could the problem be. I’m pretty positive it can’t be that every EGR valve that I am buying is defective. Anyone have a problem like this happen to them before??
assuming your EGR is electrically controlled as opposed to vacuum controlled none of the suggested repairs mentions replacing the valve.
https://www.obd-codes.com/p0404
you can try cleaning the egr and passage but did you read the link I provided?
