Power Window un-attached
Stephen0523
Member
Hi all. My driver side window detached from the arm not allowing me to put up the window. I have taken the door apart a month ago and managed to push the pin from the control arm back into the window hole, but it has come out again.
Any tips on how to get it to stay attached? I would love to put a spot of weld, but I am not sure if that will work until I get in there again.
Thank you.
The Nalley GMC site is down for some reason so I can't see what you are describing. ( picture diagram)
I have manual windows in my Sunbird so I dont know the power window system on JBodys at all.
I know the plastic guides ( 4 ) go bad and make the window fall off the tracks in the front and back.
Doug in P.R.:cool:
Hi all, I called the local dealer and they were able to order the round fitting as shown!
Mine ( wheel - roller) is white plastic, I would have to drill the whole thing out to replace mine.............;)
Glad you figured it out, my modem box took a dump so I was off line for a day and a half.
Doug in P.R.:cool:
