Dr. Sievers
So having a problem shifting. Car is 1985 Pontiac Fiero SE 2.5L 5-spd isuzu transaxle.
Symptoms are: Notchy and hard to shift, Revs drop slowly between shifts, clutch has to be depressed all the way to the floor in order to engage, Third gear has grinded about a couple times, not a constant thing, reverse fights me a touch too, shifting into first and second are the hardest but only about half the time the other half the time it engages almost fine.
Done so far: Inspected the clutch pedal it actually is a little higher than the brake pedal, it looks like someone has bent it once before, the shaft of the pedal has grind marks on it as if someone has used a set of pliers on it before. Also looked at the master cylinder, I cannot see any leaks around it. fluid is brown though. slave cylinder appears old but fine.
Personal thoughts: I was told that these clutch pedals are made from aluminum in 85 and 86. And someone else said that the clutch pedal is supposed to be elevated about an half an inch to an inch higher than the brake pedal.
History: don't actually know much, but, I do kow that when I drove this car home about a month and a half ago that the slave cylinder had a little fluid on top of it, but, that fluid did not look like hydraulic fluid. It looked more like oil. Only time I ever saw this too.
Alright Oreif where are you... lol
Someone else just told me that I should try bleeding my clutch line and see if that will help. I think that this one makes the most since to start with so I'm gonna try this first. I'll let you know of any changes.
