Problems with Drivers Door
01FirebirdVert
Hi all new to the forums.
So heres the deal I have a 01 Firebird vert. After turning the car off when i open the Passengers side door the Radio turns off like it should, BUT when i open the drivers side it stays on. Where is the sensor for this located in the door so i can test and possible replace it. I dont know much of the cars history but i can tell it was a kids at 1 point and in an accident cause the drivers side door is from a 95 bird. and it has 18's and HAD all the windows tinted.
Does the car have courtesy lights that come on when you open the passenger side door? If so do these lights come on when you open the drivers side door? If the answer is yes to the first question and no to the second question I would start checking the door switches located on the body.
