Kevlar
Hi guys.
I also have a 96 Grand Am with the 3.1L. I've been experiencing something similar. Now, I recently had the head gaskets replaced by a reputable local shop where they also found and resolved some issues with the fuel evap system.
Not long after getting the car back, it started stalling at initial start up. The engine would start and run for a few seconds and then die as though running out of fuel. After a few more tries, the engine started and ran. When I'd rev it up it would sputter out like it had a rev limiter at around 3700 rpm. All this happens with no SES and no fault codes.
I initially thought that the fuel pump was fault and went to the cost and trouble of replacing that myself. After, it started more reliably but still sputtered out around 3700 rpm. Now it is stalling at start-up more consistently so, it's likely that replacing the fuel pump my have been a waste of time and money.
It was suggested to me by a helpful lady at O'Reilly's that it may be a faulty cam or crank sensor. I then sought out this place to see if there may be some further info here on the subject.
Also, I've found that if I spray engine starter fluid shots into the MAF body the engine will eventually continue to run on it's own.
If this rings any bells with any of you folks, I'd be interested in your kind suggestions. I will check the fuel pressure regulator as suggested above. Otherwise, I'll probably take it back to the mechanic that has been doing the work for me and see what he finds. If I find the fix there, I'll be sure to share it with you all.
Sorry for the long first post.
