pulling my hair out
luvit4it
need a little help i have a 87 gt. it runs fine tell it hits normal temp then it starts sputterin any iedes.
you could try getting a new radiator or hoses. check your valves as well sometimes they come loose or they get clogged
Yes, A couple of things.
Ignition Module could be going bad. Once it heats up it causes misfires.
Pick-up coil inside distributor could be corroded. Heats up and expands causing intermittent pulses.
Fuel pump could be going bad. Heats up and pressure decreases.
You need to find out if the sputtering is ignition or fuel related.
What things have you already checked?
