Quick Answer for Repair
SGPHIREWIRE
PA
Alright well, never figured out back issue for my car swaying after letting off throttle.
I've been told its either one of the 3.
1. Bushings
2. Ball joint
3. Alignment
Symthoms rubbing noises while driving, (take 2 fingers and put it on surface of desk and move in circles fast thats the sound, loud enough to hear over car) Also when leaving off throttle it sways back and forth. (Its the rear of car) Back right tire looks bowed a bit i've been told (I can't see it).
Quick Answer - Take it to an alignment shop.
The Fiero requires a 4-wheel alignment due to independent suspension.
Even if a front wheel is out it can act weird.
If something is bad they will tell you.
The fact is I don't got 80 for something that if its not the problem I'll have to pay for the fix and another Alignment.
my buddys 88 does this. his control arm bushing in the rear are bad. TONS OF PLAY. look into those.
