Radiator fan wiring
01gase
So I'm finishing up my 2000 grand am se1 v6 runs good when I went to install the fans cause old ones were missing I found out the connectors were cut off and I can not find the wires going to the fans. Can someone tell me where to look and witch wires go to witch fan? I could make my own wire harness for the fans using relays and a toggle switch but I really wanna keep it factory
Have you googled '2000 grand am fan wiring diagram "?
I don't need the diagram I need to know where the harness that has the fan wires run. I have a service manual but it don't say if it runs behind the headlights or where basically I'm asking for a pic of the fan wiring showing the routing
Have you tried a local salvage yard to see if they have one from that generation to look at?
The closest one is 2 hours away it be a bit before I can make it there. I may just make a aftermarket harness with relays
Maybe someone with that generation Grand Am will see your post but otherwise I'm out of ideas on how you are going to see the detail of how the wiring harness was installed.
