Radio Doesn't Shut Off!
JDish
Wisconsin
On my 2000 Ponatiac Sunfire GT 2.4L i had new stereo and speakers installed last summer (July 2012) and I had a remote starter installed right before Christmas (Dec. 12, 2012) and last night when i went to exit the car, i took the keys out of the ignition and opened the drivers door and my radio continued to play and i could not get it to shut off. Also the dome lights do not turn on when i re-open the door from the outside. This is the first time this has happened since i have owned the car.
*Side note-My car door was frozen shut last night because we had sub-zero temperatures and a good bit of snow but this isn't the first time that the car door has frozen shut though.
Sounds like the door switch is frozen. If you expect temperatures to rise see if it resolves itself. Otherwise you will have to see if water has frozen in the switch.
i know that happened to my car about the radio and i had to install a relay so maybe install one of them for your radio and speakers etc.
