radio will not turn off
Reff2828
I have a 2000 Sunfire that when the car is turned off, the radio continues to run and has to be manually shut off.
Any ideas as to what may be the issue. I suspect something electrical but not my strong suit.
Thanks
I had the same problem with my '04 Grand Am, but it didn't happen all the time. I found that the door switch was sticking. The switch is integrated into the door latch, and I sprayed some lube into it, and it has been fine since.
