Raise the seat, 2004 Grand Am
Old John T
One more question. The drivers seat on my 2004 Grand Am is too dern low. I was hoping a body could remove 4 mount bolts n rig a spacer under it to raise the seat a couple inches then bolt it back down BUT I CANT FIND ANY MOUNTING BOLTS OR ANYTHING WHATSOEVER TO REMOVE SO IT COULD BE RAISED. Is there any relatively simple or easy way to raise then re mount the seat frame and how in the heck is it mounted ??
Old John T in Indiana
Isn't there a switch on the side of the seat? Most GA's have a power seat height adjustment.
Manual seat
No switch its a manual seat NOT a power. Just wondering how in the heck its mounted and where the bolts might be removed and if I can add some height then bolt it all back in?????????
The bolts are on the back of the runners.. remove them, and tip the seat forward and pull out to remove. BTW, it's easier if you remove the headrest first.
