ready to hang myself!!!!!!!
ojcosme
easton,pa
have a 04 grand am 3.4 which keeps overheating and losing cabin heat. flushed and backflushed heater core, rad, motor, and all lines and hoses. pressure tested for a leak cause it keeps losing fluid, held 30 psi for 45 mins. I fill it, purge air, topoff, and let it idle. temp never goes over 210 while idling. I get heat again in the cabin, but after driving maybe 30 mins or so, loses cabin heat again and starts to overheat. i go and check coolant and it's low again, but not always. I keep getting air from the bleeder but have no clue how it's getting in there. no coolant on passenger floor. no coolant on ground. oh, and both cooling fans work. yes both high and low speeds work. smelled the exhaust, has NO hint of coolant to it. oil not foamy. trans not contaminated. what am I missing? almost forgot, t-stat is new and so is cap for degas bottle. *update* just used a exhaust gas tester and fluid in tester stayed blue. added a pic of the stuff I got out one of the small coolant lines on top of the degas bottle.
30 psi on the cooling system can blow out gaskets, rupture heater cores and radiators. Should not go above the cap rating for testing. Assuming you did the pressure test on a cold engine try it again with the coolant at operating temperature as that seems to be when you are losing fluid.
That happened to me in my 2005 impala 3.4. Was a bad head gasket. :( try a chemical test to rule it out. They are simple tests and will detect exhaust gases in the cooling system.
all 3 of u guys obviously didn't read the post, cause if u did u would have read that THERE ARE NO LEAKS! just as bad as the guys I work with. besides I fixed it, was a bad temp sensor not turning fans on when supposed to be turned on. I figured it out on my own cause I GOT NO HELP HERE!
You have 2 posts here and they contridict each other. Can not expect to get much help when providing bad info.
You are the one who stated the fans were working, can you read your own posts?
LOL relax man! We were trying to help. I could go into it on how you could have an internal leak but w/e. Yea the fans come on, then the fans don't come on... Sorry we didn't catch that :p
