Rear Brakes on 2004 Sunfire Coupe
  • Thread starter Thread starter tbennie
Is this a question?
Are you saying that you replaced the rear brake pads and now they seize when cold?
Rear Brakes
The rear brakes would sieze when cold during a sudden stop. Would be ok once warmed up. Pads were replaced and drums machined bu problem continues to this day. Not so bad in summer but can give quite a jolt when cold in the winter and vehicle has sat for a period of time, say overnight. I was wondering if replacing them rears with disc brakes would solve the problem.
That would be an expensive solution. I'm sure you installed aftermarket brake shoes. Remove them and install the original GM shoes I had the same problem and that solved it.
