Rear coil spring's for a 68
Jono
Hello I'm looking at getting new rear coil spring's for my 68 LeMans but factory ones make it sit lower in the back end. I'm looking to either go level or a slight rake in the back end . Any suggestions on what brand or where to order them from ? Summit only has the stock ones and that's usually my go to place..
Same year wagon springs are stiffer and higher. ( Compare them - "specs" with stock before purchasing on Moog or RockAuto sites , wire thickness and height)
Doug in P.R. 😎
How are you getting "factory" springs for a 68 from GM, they dont make them anymore.
Try Eaton springs and look at the 68 GTO/Lemans MC5065 HD springs.
Sorry meant stock not factory and thanks Sunbird I'll look into that .
Thanks Sunbird I went with the ones for the wagon gave it a slight rake and no more tire rub thanks again
