Rear Lift Gate Switch Not Working
jclarke
I am New to this Forum. Hope someone can Help me out. I have a 2009 Pontiac Torrent and the Rear Lift Gate won't open. I checked All Fuses and they are OK.I took out the Relay Actuator and applied voltage using external battery and the relay is working. I was wondering how to check the Switch? Can I take it out and check continuity with a meter? Is there a Wiring Diagram for this Switch? Any Help would be Much Appreciated.
does it open with the remote?
No it won't open with remote or using unlock on doors either.
Is there a Wiring Diagram around that I can refer to?
Thank You for the Link. Lots of information. I am a bit confused though. There is a Liftgate Switch and a Liftgate Latch mentioned. I would think that the Liftgate Latch would be the handle located under licence plate. So where would I find the Liftgate Switch?
