regular weird sound in 80+ kmh speed
mirec73
Hello,
I just bought used 2003 sunfire 2,2 gt.
When my speed is near 80kmh and more it starts doin regular noise in 2 second interval and it sounds like you drive above texas gate or something like that.
Please can u suggests me what it might be? Thanks
Can you tell whether it is from the front or back? Have you examined all four tires for any cracks, bulges, belt shifts, etc.?
Hi,
Tires are good.
Sound is coming from the front and it starts to be louder after 60km/h. The higher the speed the more regularly it comes and louder.
I tried to steer the wheel and it was not doing only i was steering to the right. So straight and left always bad. I have also check engine light on but i guess its not related.
it could be a bad CV joint causing the noise, check to see if you hear it at low speeds with the wheel turned fully to the left
