trpreacher
- Feb 22, 2016
My wife's 2008 torrent has bad rear passenger wheel bearing. I removed the wheel, rotor, and after removing the four retaining bolts the hub came off attached to the "backing plate." I can't get the hub assembly out of that back plate which is now off the car itself. I've PB Blasted it like crazy, used heat, threaded the bolts back through that back plate and tried to hammer the hub out with a socket over the bolts. I rented a slide hammer and flange, but that doesn't really help separate the assembly from that plate with the brake hardware on it. Do I have to disconnect the emergency brake to get that hub assembly out? Please tell me I'm stupid and overlooking something simple! Any advice welcome as I'm currently stranded with my wife's car and a bunch of people depending / waiting on me. Thanks!!!
