removing the door lock cylinder
tony0598
Alrighty then I got a new lock for my driver side door because someone decided to break in and have a look around, I got the panel off and I can't figure out how to remove the cylinder itself and place in a new one, if someone can explain this to me or direct me to a site it would be of great help and save me money on a mechanic
what exactly is the problem? can you see the cylinder? typically they are held on with a horseshoe shaped clip which you push on to release the cylinder from the exterior door panel after removing the linkage rod.
Thnk you sir! Tht right there helped me enough to get it, i appreciate ur input
