Left front turn light quit working. After looking from the top and the bottom there is no way to get to it. Did a search on here and came up with nothing, unless I didnt do it right. Googled it and came up with several different sinerios,none of which applied to my vehicle. I donned my suit of armor and went out cussing engineers from the beginning of time to the present. Upon closer inspection I see a silver colored pin on the inboard side of the headlight bucket. Turned it out from under the plastic retainer and removed it. Then I see a metal screw on the outboard side of the headlight on top. Removed it and the entire headlight comes out,giving you good access to the turn light. Turn the socket counter clockwise and it pops out. Glory be to God they left the wires long enough to pull it up so you can easily change the bulb. This applies to a 2006 SV6 hope this helps someone.
