tilliepeople
- Aug 24, 2023
While changing CV axles I found the seals are different from right and left.
My question is that the left axle only appears to go in approx. 1 inch vs. the right goes in almost 2 inches.
Does this difference make a whole lot of sense or did someone maybe put in the wrong axle.
I am a little afraid of destroying the ne axle if it does not go in a little farther.
I'm now in the process of waiting for the right-side seals as it turns out I ordered two left seals.
I already sent back the left seals and will half to reorder the correct one.
left seal has a dome and right seal does not.
