J
		Johnny M
My car was not starting and after replacing the spark plugs and fuel filter I found out that gas was not passing through. I turned the key with the fuel filter off and didn't see fuel coming out, so I figured that this was the problem. Should I check anything else less expensive before doing this? How hard is it to replace the fuel pump? Thanks in advance.
