right blinker wont flash!! pontiac grand am
  • Thread starter Thread starter sexy paco
S
sexy paco
1995? i have a 1995 pontiac grand am, and the left blinker works and everything, but the right one just stays on.no flashing, the front and back light works just the left side wont flash.
Im assuming you have checked all of the bulbs ? even if they light up sometimes the filiments can cross and short the flasher out ..
if all the bulbs check out you may have a bad socket , that year I believe had some issues with burned sockets that would loose connection , the issue required replacment of the light socket assemblys ( the dealer could tell you if your car was effected by that problem) otherwise you may simply have a bad flasher assembly ..but you will need to check all .
