Scan Code
otheym
i have a 89 sunbird and i get the scan value blm enabled no. What does that mean?
so what does blm enabled equals no mean? Open loop mode even thought the scan value says cllsd? Bad O2 sensor even though code not set?
have you disconnected both battery cables, held them together for a few seconds, reconnected the cables and repeated the scan attempt?
what would that do? We are replacing the o2 sensor.
trying to reset your ecm
