hipnhappy
Hey all,
I was going to tack this on with my previous post on the "overheating fix" I found (haven't been able to verify it works because ...), having replaced the fuel pump after doing the thermostat re-location swap, when I got everything set she fired over, ran for about 30 seconds and died. Have not been able to get her to "run" or "fire" since then.
OBDII scan shows "No Error Codes" and I have spark at the plugs, fuel on the rail and injectors are pumping. I know this by pulling all the plugs, turning over the engine watching spurts of fuel come from each cylinder, checked spark on each plug and if the injectors were pumping I have fuel. Fuel pressure was enough to run idle for 30 seconds so NEW fuel pump operating effectively.
Which brings me to the "security system" question. When I got this vehicle it had sat for a while after a head was changed out. I know and respect the abilities of the previous mechanic and since there is no valve adjustment after setting the 22fps the rest of the re-assembly appears all correct as well, this is not a result of any of the above having an issue.
I replaced the battery when I first got the vehicle and while installing it, located a small odd black box with a pair of what looked like "stereo wires" running into the firewall. I took them for some type of "Amplifier or booster" power feed so I eliminated the little box which did not seem even connected to the battery ends anyway.
Question is, "what represents the security system", did this small box have anything to do with it, can it be "by passed" and will it "prevent the car from starting" if absent from the system.
I've read a few places where "failure to start and continue to run" even with spark and fuel are present are a consistent issue with these things and have only seen one ( I guess resolved because the "poster" said "fixed" after he replaced his gauge cluster), after having tried a new electronic key and a myriad of sensors, the coil even the ECM with no results until he got a used cluster and changed it out.
So, "IS" the little box an integral part of the security system? "Will" the security system tell the ECM not to allow the vehicle to start and finally, is there any way to by pass the system to see if it is functioning or effecting start/run operation?
Thanks , will try the 15 minutes in on position and pull out the key, let stand 10 minutes after the rain quits in case may resolve the issue. Gotta be something simple though just gotta work through the various interacting components of these "miracles of modern technology". I'll take an old slant or straight six over this "efficiency through electronics" crap ANY DAY !!! LOL!!!
