spiralout1185
- Sep 10, 2010
I've seen this question asked but no successful answer, so here it goes.
A while ago, I had some on going issues with this car that no one seems to understand or know about.
First, my Trac off light will come on. When I accelerate to about 20mph it juts, and i mean the whole car throws itself into gear. I would pull over, put the car in neutral and turn it off. When I turn it back on, the light is gone but when I shift it into reverse or drive it Juts into gear again. Shortly after that first happened my Service Engine Soon light came on, steady. Sometimes it would go away if I tightened the gas cap or I would turn the car off then on, but sometimes it does not go away. Just recently, the lights came on in unison...and that's when the idling would come about. While stopped at a stop sign or a red light, my car's RPM's would go up and down, below 1...then eventually stall out. I did some asking around and some people who work on cars told me about the IAC valve needing a clean or to be replaced.
I got the IAC valve cleaned, but the lights still come on and I'm starting to notice the RPM needle doing it's dance again, but not as often as it was before it was cleaned.
CAN ANYONE help? Has anyone had this problem or at least know what it is?
