Several codes flashing
sarasandy
2005 Montana shows service traction control, service AB, service stability control--flashing on dash. Goes away once car is stopped. Had it checked and no codes/problems show up. Any suggestions?
You had it checked at what kind of facility and what device did they use? You need special scanners to diagnose codes in the systems you are mentioning. Check for a broken connection at the wheel sensors.
I have the same issue but my codes r
C0253- centering fault / ecbm circuit fault
C0040 rf wheel speed sensor circuit malfunction ...
I know the c0253 is the steering wheel centering sensor but how to relearn the center is where I'm stuck can I do it on my snapon brick ?
ImageUploadedByTapatalk1404825106.193455.jpgImageUploadedByTapatalk1404825106.193455.jpg
Awesome now I know where to start! I knew the wheel bearing was good. Good ol wire rub.. I'll check it out ASAP just had back surgery 2 weeks ago so I'll be layed up for 2 more
