bluesmokennoise
Member
- Aug 14, 2023
Attempting body work on a 91 Pontiac Sunbird LE cutting out the rust on the outer door panel. but have neither equipment nor expertise using welding gear. My plan is to just affix sheet metal to the inside of the door panel with seam sealer, then apply self-adhesive metallic body patch followed by body filler, smoothing, sanding and painting. What kind of sheet metal would you guys recommend to use that is primarily just a reinforcement of the body patch and body filler? Galvanized? What would be best? I am somewhat concerned about the rusting. I'm also replacing both power window motors and the rust I discovered inside was staggering so I am not wanting to do this repair using the wrong kind of sheet metal.
