Shifter moves freely and wont engage gear
dimevision
The shifter when moved to select a gear moves freely as if its not catching, went to look under the hood and found that the rod has fell off its bearing connector. Is there a way to fix this without replacing the entire thing or can i buy another "grommet" and reconnect it?
