Signal lights issue
TJCOLD
Was wondering if anyone else has ever experienced something similar. So I swapped over every 1157 bulb on my 72' Lemans with a Led version. (6 tail light bulbs and 2 front signal light bulbs. After some finessing they all maintained power and lit. However I have a problem with left and right signal no longer working.
  • Brake pedal - works fine
  • Hazards - works fine
  • Parking - works fine
  • Headlights activated - works fine
  • Left signal - No flash ( solid arrow light on dash)
  • Right signal - No flash ( solid darrow light on dash)
Signals worked just fine with the original bulbs.
No sure where up start. Any ideas?
I watched the video, before tossing the bulbs make sure you are using an LED flasher. You may need two, one for signals and one for 4 way.
Yeah my bulbs look nearly identical to those in the video. However I didn't know to get an LED flasher
