Ok So. Ive read alot on this issue and here is my problem.
The Hazards, Signals, And Brake Lights Dont Work In My One Sunfire.
I Switched The Module With My Other Sunfire, And Everything Worked, So Returned It To The Original Car.
I Switched The Relay Under The Dash With The Other Sunfire, It Works. Left Them Both Switched Up.
I Switch The Brake Button Under The Dash With The Other Sunfire, It Works As Well.
Switched The Relay Fuse With The Other Sunfire, It Works. Left Them Switched
Cleaned The Battery Terminal And Even Switched The Batteries. It Works.
All The Fuses Are Fine.
Even The Ones Under The Hood.
This Sunfires Signals And Hazards DONT turn on, Theres No Clicking, Not Even Once. Ive WD-40 The Hazard Switch But It Still Doesnt Work. Im Stumped....
Pease Help.
Pease Help.
