so a 350 WILL bolt up to the tranny on my firebird?
David
heres the deal, its a 1997 v6 firebird 3800 series, i want to upgrade the motor without replacing the tranny, simple swap, but i want to know what will work before i do of course. is the 305 really that badd,? thanks for all your opinions.. adn will a 350 really bolt up to my tranny, wouldnt i need to upgrade the tranny, anyway, thanks for the help!!!!
Unfortunatly the trans in your car will not bolt to any V/8 you would need a V/8 bellhousing transmission, and yes 305s are pretty much junk unless you are going to just drive the car like you did with the V/6.
plus just putting a 305/350 in is not a simple swap it takes a bit of fabrication and skill to do you would be better off just replacing the V/6 with another ...
