spark plug rust
white123
Hi
I have a Sunfire 2001
I would like to change the spark plugs but
I have rust and dirt in the hole
around the spark plug
I put rust Lub in the hole and let it sit
I think the plugs would come out
my only problem is that I do not want the dirt and rust to fall in to the engine block
hope some one can help
If you have a shop vacuum quite often the hose will connect to the outlet and you can blow the debris out.
Hi
thank you all for your help
your help full tips worked
I was able to change the spark plugs
with no problem at all
and the car runs better .
thank you
