spindle nut size on 2009 torrent
Joe Weger
googled it said 36mm which is to loose in my opinion so is it 35mm or 34mm ?
Do you mean the socket size or the inside diameter of the nut?
I find 36 mm on a 2009 but if the axle was changed, some are 35 mm..
You could make up the space with duct tape
Older Torrents use 30 mm nuts
Take it off and head to the parts store...
Doug in P.R.😎
